Argh! Grrrr! *****! multimedia key!!!!!
8 replies · 5,002 views · Started 21 June 2007
Make it go away!! Its pants! Its cabbage! Its so annoying. When writing a text, i go to press 'c' to delete sumink and end up pressing the multimedia key above. Cant i take it off or remove it or sumink?
Just set a repeating alarm and let that go off once, then the key will stop working! Magic! 🙄
Yep me too. I think this is an aspect of the D-pad that needs improving.
well i'm confused re: good tip.
you're saying you can type from the keyboard but the multimedia key will no longer be active when an alert is posted?
yeah.. what's up with that? i noticed too the multimedia key won't work at all sometimes, either pressing it down lightly for the menu or holding it down for music player. restarting the phone will fix this issue, but why does it stop working!?
