Setting up GPRS in Windows XP?
1 replies · 2,378 views · Started 23 June 2007
So on my Mac I use my N95 over bluetooth with GPRS... How do I set that up under Windows XP?
steffi wrote:So on my Mac I use my N95 over bluetooth with GPRS... How do I set that up under Windows XP?
You either need to install PC suite, though you dont have to but its the easiest option. Then select connect to the internet in pcsuite.
