Hi all,
Got a question about the new 4gb card thats out now, in particular the one on MobyMemorys website.
It says the speed and performance rating is
Speed performance rating: Class 2 (based on SD 2.00 Specification)
Exactly what speed does it do?
Is it the same as the UltraII at 10mb/s Read 9mb/s write or more/less.
Gonna wait if it is coz with this size the faster the better.
Crispy
CrispyDuck wrote:Hi all,Got a question about the new 4gb card thats out now, in particular the one on MobyMemorys website.
Crispy
While its great to say the card can read and write fast but can the phone actually access it at the speeds it talks about, no one has mentioned that.
My 4gb card just arrived from MobyMemory, works well. Not sure what difference a faster card would make as this seems the same speed as accessing the 512.
Neil:icon14:
just got mine also, its noticibly faster than my 2gb sandisk micro sd card, im so happy now ...
Crispy
"SanDisk's Micro SDHC is rated a Class 2 device - not that you'll see this mentioned on the card itself, as SanDisk isn't keen in this rating - which means its capable of a minimum guaranteed data transfer rate of 2MBps. "
Source: http://www.reghardware.co.uk/2007/06/12/review_sandisk_4gb_microsdhc/
Many thx Dez
Page 2 on that link was what i wanted to see.
Crispy
2MB - 16Mb????
MB = Megabyte
Mb = Megabit
neilmallon wrote:My 4gb card just arrived from MobyMemory, works well. Not sure what difference a faster card would make as this seems the same speed as accessing the 512.Neil:icon14:
It makes a HUGE difference - especially when you are recording video on the phone. I have a cheap 2GB card and whenever I do video on it, it will stutter once every minute or so and I lose about a second's worth of frames. This does not happen when I put my Nokia 1GB one back in.
The lag is very noticable so I do not recommend anyone to buy cheap slow cards if they are to record video on it..
Biggzy wrote:just got mine also, its noticibly faster than my 2gb sandisk micro sd card, im so happy now ...
Where did you get yours and what app is that?
got mine frm www.mobymemory.com and that app is handy taskman, email me and ill send it, [email][email protected][/email]
I just received my card from mobymemory today. Quick question though, I can't get my computer to recognize the card.
Any ideas what I'm doing wrong?
are u using the suplied usb card reader? As most old card readers wont read it
CrispyDuck wrote: Got a question about the new 4gb card thats out now, in particular the one on MobyMemorys website.It says the speed and performance rating is
Class 2 speed only guarantees 2.5Mb/sec read and write. UltraII is 4 times faster. Currently most of the 4Gb cards are only Class 2, and that's disappointing (for me).
Will a Class two card mean that when you take video it will be a bit Juddery?
Occasionally my 2 gig card does that so I'd like a faster card, but not sure what speed it is.... unless class two is the slowest in which case the 4 gig will be the same ans the one I have.
Just purchased a Sandisk 4GB MicroSD Card with Free USB 2.0 MicroSD Card reader for �44 inc delivery 😊
dez_borders wrote:Class 2 speed only guarantees 2.5Mb/sec read and write. UltraII is 4 times faster. Currently most of the 4Gb cards are only Class 2, and that's disappointing (for me).
actualy the class 2 guarantees 2 mb MINIMUM read/write speeds, with the suplied card reader it takes just over 3 mins to copy 1gb of data to the card using pc, thats alot faster than the ultra ll cards
