mms setings
4 replies · 2,426 views · Started 23 June 2007
been on o2 website and cant see an option for n95 mms settings...my phones not sending or receiving mms picture messages
can anyone help me with changing the settings?
thanks
thanks a lot from that.
dwloaded all 3 of them and insalled them all and it still wont let me send them!!!
just keeps saying "resending at..."
incidentally, apparently texting "active" to "2020" will get settings for you too..
gritbox wrote:thanks a lot from that.
Are you a new customer to 02, as they sometimes don't initially enable MMS, you may have to ring them and tell them to enable MMS. Ring and check with them, this happened to me when i first joined them. Even though the tariff had mms allowances, ring and check with them that MMS is enabled before anything else.
hmm, feelin a bit daft now...(though i wasnt told so how would i know!?)
apparently u have to switch fone off and on again to load them properly...oops!
works now, thanks a lot
