Looking for N95 Owners To Test High Quality Video Stream
9 replies · 6,066 views · Started 24 June 2007
We are looking for N95 owners to test our high quality video stream sample. We are working on encoding a group of videos for higher end mobiles like the N95 and could use some feedback.
Send me a message and I can send you the link to the ZooVision labs page.
If it works well for people we will add more of our videos to this higher quality encode. Thanks in advance for your feedback!
Sean
ZooVision
I took a look last night and it looks pretty good altho no better nor any worse than the mobile tv being 'broadcast' by the operators. The BB feed on T-Mobile is probably the best I've seen and would say this was on a par with that.
Now what I would like to see is video streamed the quality of which would look good when using the tv link !
I would post the link on this thread if I had that privilege. Can someone who can post links add it to the thread? Thanks!
Sean
ZooVision
Hi all,
Two things firstly in the address although it doesn't show on the link posted there is a under score in it so it should look like
http:/www.zoovision.com/mobile_zoolabs.html
Having watched the V Power clip from this link and then the original @ the ZooVision site there is a big difference IMO in the smoothness and quality. Which IMO proves the advantage and need for the better processors and graphics chips. I would imagine the N81/N82 will most probably be the last OMAP2420 chip devices and the the new devices that launch early next Year will start having the Series 3 chips with all the improvements that this will bring.
Marc
