I have the current firmware installed and thought i would check to see if there was another, however when i did it told me that nokia updater needed updating so i let it download the newest version.
after that it won't search for an update and tells me that there has been an internal module error??
the phone works fine and it only seemed to happen after the actual updater was updated?
says now that current firmware is 6wk41v23.4???
phone says v11.0.026
anyone else had this problem or know why it might be?
jonathandr wrote:I have the current firmware installed and thought i would check to see if there was another, however when i did it told me that nokia updater needed updating so i let it download the newest version.after that it won't search for an update and tells me that there has been an internal module error??
Try disabling both your Firewall and Visur Checker when you launch NSU. On my PC NSU only works with them both turned off.
If this doesn't help, uninstall NSU, reboot the PC then reinstall NSU.
I don't think your problems are related to flashing your phone FW, but more likely due to the NSU app upgrade installed on your PC.
Uninstalled and re-installed NSU, now works fine
