Queries for my N80ie
1 replies · 1,897 views · Started 25 June 2007
1. Is there any development in unlocking the n80ie ?
2. My friend gave me a jabra 250v a few weeks ago, and I have managed to pair it and use it for 2 weeks. On the 3rd week I can not hear anyhting from the bletooth headset anymore. I used the headset on my PC for skype, and it works fine. Is my N80ie the problem? if it is what shall I do?
3. Recently my phone hangs a lot, what should I do? update my FW?
4. Can the new 4gb sandisk card work in my n80ie with an upgraded FW?
Thanks for all your help
1. No... you cant. That the whole purpose of locking it.
2. Cant say... could be either but 3. could help
3. Yes, update it ( 5.xxxx whatever. It might help but no guarenteed. Id only update now if I had a problem worth updating for as you do)
4. No... the max is 2GB. You cannot use 4GB in any f/w and never will be able to on this phone.
