Dvd Quality On N95!!!!
41 replies · 11,603 views · Started 25 June 2007
this is a fantastic filter created by an italian user(ficofico)..this filter produces a very very very good movie from an original n95 video!THIS IS DVD QUALITY!development of this filter is in progress...now this filter has a few of problems(video and audio are async with vlc or kmplayer for example,but are in perfect sync with windows media player+ffdshow)..this filter isn't ONE-CLICk,but ficofico is working for this!
STEPS:
click on Per installare il programma\CLICCARE QUI PER INSTALLARE I COMPONENTI to install all programs
rename your movie in originale.mp4
copy this file in Rigenerator N-series\Rigenera a 60 frame al secondo (suggested)
open media info,select originale.mp4 e watch frame rate
then open Rigenerator N-series\Rigenera a 60 frame al secondo\istruzioni.avs with notepad and modify in the first line frame rate with correct frame rate showing by media info
click on AVVIA LA CONVERSIONE
ending process will be generate a movie finito.mp4 !!!
Hi
I've installed this new version but always get the same error:" Unsupported input format <DIB >"
"Could not open input file istruzioni.avs"
The input file is a movie downloaded from my N95...
install correctly all programs...
put your movie renamed in originale.mp4 into rigenerator n-series/Rigenerator N95-N93-E90
click on avvia la conversione
fenomeno83 wrote:install correctly all programs...
What do you mean? it's a "double-click" installer...i've done abot four times and always get the same error
(fenomeno es del espa�ol???)
fenomeno83 wrote:it is impossible!!you must install ffdshow codec and play movie with windows media player
Yeah...
I did that. I installed this one: free-codecs.com/download/FFDShow.htm
I tried twice. I get message that it is mp.4 and it is not recognized by WMP.
On Nokia player codec error and audio only. Same on QT. :con?
try with windows media player 11..try also with vlc that has all codecs integrate(but video and audio will be async!)...it is very strange...can you try movies in another pc?
fenomeno83 wrote:try with windows media player 11..try also with vlc that has all codecs integrate(but video and audio will be async!)...it is very strange...can you try movies in another pc?
Yeah, I already did that...
It works fine on my laptop...
Something must be messed up with my pc...
EDIT:
Thanks for help...
I'm gonna try your filters as well.
Looks good
Hope I manage to make it work 😊
No luck :frown:
I'm getting "This application has failed to start because d3dx9_30.dll was not found."
I reinstall the app.
I tried on my laptop as well with the same effect.
Any ideas?
Ok. I downloaded the .dll file. It seems to finish. I have the finito.mp4 file but I can't watch it though (even on my laptop, where yourfilms played ok).
When I'm opening, WMP plays the sound but on the screen I see unknown systm exception error. On the WMP screen on the top.
I give up. Not worth the hustle....
My little review on this soft: USELESS
Reasons:
1. Hard time to make it work,
2. Hard time to watch the final (even this films from the fenomeno83 link won't work on my desktop, only on laptop, god knows why). Though , I can't watch my finale.mp4 file even on my laptop. When I'm trying to do so, WMP plays the sound but on the screen I see unknown systm exception error
3. After installation Windows Live Messenger gives me errors
4. Windows Media Player hangs when I hit ctrl+o (never did that before and nothing else was added/changed)
Uninstalled the application, restored to the pre-installation point and cleaned registry.
Fixed my WLM but WMP still hangs... need to work on that 😛cguru:
Thats what happened on my comp anyway.
I'm not saying that the soft doesn't work at all.
It's not working for me. That's a shame as I really like the final effect.
(IMO)
fenomeno83 wrote:post your movie finale.mp4 on megaupload..you have any problems on your pc...:frown:
Don't worry... 😉
I try to find some other soft...
Do you know one by any chance?
