the real use of the multimedia buttons!
2 replies · 2,032 views · Started 25 June 2007
Does anyone really use those multimedia buttons (the ones that appear when you slide the phone down) ????
Personaly I never used them .. Instead the D pad does the work .. Dont you think it is awaist .. and that space could have been utilized better ??
aldosari wrote:Does anyone really use those multimedia buttons (the ones that appear when you slide the phone down) ????
Yeah I tend to agree, I don't have much use for those keys. I think the multimedia keys came as a direct result of the widescreen slider-function. Sliding it to the right just meant there was some free space on the left. Nokia just decided to make use of the extra space.
daffie wrote:Yeah I tend to agree, I don't have much use for those keys. I think the multimedia keys came as a direct result of the widescreen slider-function. Sliding it to the right just meant there was some free space on the left. Nokia just decided to make use of the extra space.
I hope they utilize it better in the future .. dimensions and wieght is a major factor in mobiles now ..
