hi all
new to the forum as i just bought my n95 last week!! wat a gadget packed phone i may say!
have one question can the phone file share via a wireless connection to a computer or do you need a third party program involved?
thanx😎
hi all
thanx😎
crash19999 wrote:hi all
new to the forum as i just bought my n95 last week!! wat a gadget packed phone i may say!have one question can the phone file share via a wireless connection to a computer or do you need a third party program involved?
thanx😎
I suggest you first search this forum. It's been discussed and explained many times already. There are several possible solutions/products with different pros & cons. 😉
If you can find the threads please post here as i would be interested in this but cannot find anything!
SymSMB is what you need my friend.. You NEED version 2 and above so that you can have the client/server relationship. Its pretty good but still fairly slow to transfer. But does work natively!
Basically your waiting for www.telexy.com to release version 2.0 of SymSMB 😊 should be soon!
sorry about that superswede but there a some very confusing posts out there,
i could do with a step by step instruction if anyone has one???
bchliu can you tell me if the version 1 works at all on the trial as i have tried that but can't get it to work, i mean it installs on the phone but cant find the phone on my wireless network!!
thanx
Version 2.0 is now released, I can browse to the phone share with XP SP2, but NOT Vista. Vista says it cant find the network directory.
crash19999 wrote:sorry about that superswede but there a some very confusing posts out there,
i could do with a step by step instruction if anyone has one???thanx
Instruction based on N80 but applies for N95 as well (personally I didn't need to install the "Home Media Server" software. After enabling UPnP on PC and WLAN router I could connect to Windows Media Sharing feature in XP (I'm running Win.Media Player 11)):
http://thinkabdul.com/2006/09/23/tutorial-setup-wifiwlan-file-sharing-for-nokia-n80-via-upnp-with-home-media-server/
Home Media Server:
http://www.simplecenter.com/nokia/
symsmb .. new version 2 allows read/write on networked drives ..
http://www.telexy.com/Products/ProductInfo.aspx
free trial .. see if it does what you require
thanx guys i am gonna give that symsmb 2.0 ago on the trial version
i will let you know how i get on
