MMC problem, password
9 replies · 13,971 views · Started 12 January 2003
does anybody know how i can format my MMC? i forgot the password already since its been so long and i was stupid enough to place one.. now i can access it. is there anyway i can format it?
ive tried opening it thru file manager but when i tryu to format it, it says locked. but something weird happens.. when i put certain a password it says Note "note not found" "not supported" but if try other passwords it says incorrect password.. is it possible dat my MMC got corrupted?
Wow...you shure have strange problems... 😊 .
Try with a card reader...as snowmobile suggested,I don't think your mmc is corrupted...
your mmc format use card reader and
go to ms-dos
please command :
win98 or winme or winxp
format v: /fs:fat /a:2048
v: drive your mmc
a: 2048 your mmc 128Mb
a: 1024 yuor mmc 64Mb
a: 512 your mmc 32Mb
thanks
apung wrote:your mmc format use card reader and
go to ms-dos
please command :
v: drive your mmc
thanks
It tells me : Error in IOCTL call. (my mmc is locked by password)If I'll try to format the card in another card reader u think it will work?
go to ms-dos
please command :
v: drive your mmc
thanks
this is what i am getting......it just making me mad please help me out
C:\Documents and Settings\rahul>format h: /fs:fat/a:512
Insert new disk for drive H:
and press ENTER when ready...
Error in IOCTL call.😡 😡 😡 😡 😡
What to do?????:con? :con? :con?
Throw away the card and get a new one, if you have forgotten the password you (or somebody else) set for the card. If it was easy to bypass the password, it would be a useless security feature. If you have really valuable information on the card (worth much more than new cards cost, you can ask a data recovery service, such as http://www.ibas.com/ to help).
