Faster menu's?
12 replies · 3,412 views · Started 27 June 2007
Found this info in another forum. Duno if its well known? I tried it but duno if i can particually say its worked? Not sure if 'reboot' means reset, or just switch off?
'The to-do option can be found under calender. Once you open your calender select to-do view from options and then make the entries mentioned below.
Follow these steps
First go to ur To-do List.
Make a note and input as follows
Subject: Speed
Due Date: 29-01-2005(dd-mm-yy)
Priority: set to High
then press Done
Go to option again and make a second note and input as follows
Subject: Qoukie
Priority: set to Low
then press Done
Do not exit yet. Highlight the Speed note, select Options and Mark as done.
Then highlight the Qoukie note, select Options and Mark as done.
Now, reboot your mobile.'
That sounds completely random!
Like "If you press 6, hold your nose, spin round 3 times, press 7 7 1 4 and then lick the screen, the battery will last longer"
Ha ha! I found it in a serious legit 3g forum. The seemed convinced it worked. Have you actually tried it? Try tapping ur nose as u do it if you like....
Things like this always seem to pop up for S60 phones.. They never made a difference before!
3Shirts wrote:(...)"If you press 6, hold your nose, spin round 3 times, press 7 7 1 4 and then lick the screen, the battery will last longer"
I tried that...
doesn't work 😡
3Shirts wrote:That sounds completely random!
Ok just to make sure I am not missing any step .. when I lick the sceen, is it normal licking or I can go wild and naughty ? 😎
Hi gang,
I read this post B4 on another forum...
It has now 2134 reply's
So please stop it at this serious forum.
This is a hoax and all of U know (if U think clearly) that a note won't and never ever change symbian OS operating systems...
Come on!!!!!
Hi rolan73d,
rolan73d wrote:Hi gang,
Come on!!!!!
I disagree. Of course from a pure technical view it *could* be a developer-backdoor to change system settings.
I am NOT saying here that is does anything or that kind of backdoor makes sense at all, but I disagree, that it is impossible.
From a personal point of view I also tend to think that it is a hoax, don't care anyway.
Regards 😊
PM
So, what, we can't all have a bit of a laugh on here because it is a 'serious' forum? I am enjoying this thread so jog on
