Looking for a cheap but good spare battery to carry around in case of high usage =- anyone got any good ones??
Spare Battery
You can't go far wrong with an original Nokia one. It is available on w*w.blueunplugged.com for �18.95 (if you're in the UK). I would only really recommend original manufacturer batteries - the unofficial ones are cheaper, but you never get anything like the life out of them that an original Nokia battery will give you
