msn messenger (china) problems
3 replies · 3,212 views · Started 27 June 2007
i was lookin 4 a good msn to use on phoen and best i found was the msn messenger from china which worked great, but after upgrading teh firmware, it no longer works and just says it is not usable out side of china and tiwan. i havnt changed any settings and have tried both hard and soft restes as well as reinstaklling. nothing helps
any one got any ideas?
thanks
yeah, the chinese version runs out after a while... shame cause its a good app.
Anyway, I assume Mig is a workable app as would be something like Fring.
