Hi all,
I have just purchased a Nokia N95 with internal GPS, I have previously used TOMTOM on pda but the phone runs on Symbian. I do have a UK version of Route 66 for symbian phones, but no Australia Maps.
What is the best software?
I have heard that TomTom won't work with the internal GPS, but Route 66 does!
If Route 66 is the only or best then where can i get an Australian map because the website wants to sell you the whole package again, not like TomTom where you can just get the maps.
Please help,
Kind regards
Mark
Thanks for that,
I tried to use the map but its blank apart from the water areas, is there a setting or something i need to do.
Thanks for the link
Mark
download route 66 for the N95 at:
(http: / /) alex.p2pforum.it/2007/06/09/route-66-mobile-v73486n95_unsigned-maps/
dajaja wrote:download route 66 for the N95 at:(http: / /) alex.p2pforum.it/2007/06/09/route-66-mobile-v73486n95_unsigned-maps/
cool thanks, i will download it now and try to install it 😊
I would like to know from those that have used route 66. Is it better than the MAPS (smart2go) software that comes with the N95. I have limited space on my memory card and was wondering which one was better?
Thanks for the program.
But from where to download the maps for Scandinavia?
Have seen the program for about 85 Euro in a shop. But could not find a demoversion on the internet so that I can test the program for a couple of days befor I decide to buy it or not.
/Geraner
minglau770 wrote:cool thanks, i will download it now and try to install it 😊
I have download the software. But i am having problem installing it.. it wont let me.. could someone please help me pls... i really want to try the software out before i buy it....
davesmith wrote:I would like to know from those that have used route 66. Is it better than the MAPS (smart2go) software that comes with the N95. I have limited space on my memory card and was wondering which one was better?
hi, dave
yes route 66 is much much better then nokia maps! if u got limited space on your MC i sugest buying a bigger one,like 2 gb for around �15-20 then u got plenty space for whatever u want(pics,apps,movies....).
hope this helps mate,
glavaa
I have download the software but it still doesnt work.... i have try to get it signed but no luck could someone help me pls
