sDoubler 1.20F and Stacker 2.05 Bug
9 replies · 2,140 views · Started 13 January 2003
sDoubler
the annoying little doubler scrolls the bottom of the screen when you exit messages.
Stacker
After program exit stacker was not able to compressed the program Handy Clock. Error was... App is busy! after a few minutes tried to compressed it again i still get the same error.
sDoubler
U can disable it u know!!!!!!
It's not a bug. It scrolls because its trying to compress if anything is compressable. To disable it, go to SDoubler, move joystick to the right to go to Files tab, scroll down to Messages, Options, Disable group.
HeySimply258 if the doubler scrolling is such an annoying thing for you !
I think you really need another hobby quickly!!!!!!!!!!!!!!!!!!
At least wheen it is scrolling you know the program is working.
Life is a beach & I should be on it now!!!!!!!!!!!!!!!!!!!!!!!!
[quote="MaleBuffy"]
sDoubler
U can disable it u know!!!!!![/quote]
Easy Muffy. 😊
