N70 Goto menu
1 replies · 2,304 views · Started 29 June 2007
How to add shortcut items to goto? i want to add Bluetooth, contacts, Profiles to GOTO option.
My current defaults are Inbox and Calender.
But even when i went to Inbox and Calender, it didnt gave me option to add to goto, so what if suppose i delete them in future n want it back again??
Use the following software AppMan v1.04 and use "add to favourites" from it's option menu (you have to circle through the tabs to find it) to select any program to go to "GOTO". But remember not to put more than 14 shorcuts including the default calendar, notes & inbox shortcuts or else, the goto will start malfunction.
http://www.eliphs.com/mac/AppMan_V1.04.sis.zip
Incase you do put morethan 14 shortcuts, then to reset the goto from mal functioning just remove the file "Pinboard" from "C:\system\data" using "FExplorer".
Don't worry, when you start "goto" again, the pinboard file will be recreated again with default setting.
