Mobiola warning for Vista users
2 replies · 4,070 views · Started 29 June 2007
Mobiola webcam doesn't work with Vista!
I tried it because their site said it was compatible, it did work and was great so I paid for it. THEN I put the PC to sleep and when it woke up, it bluescreened (the first I've had on Vista!), rebooted, bluescreened again and did a memory dump then finally rebooted and was ok. I was able replicate the problem every time I used sleep and quickly discovered that uninstalling Mobiola resolved the problem.
Evidentally, the driver it uses causes big problems for Vista which I bore out with various forum results from a google search.
I am running Vista Ultimate 32Bit Retail.
You are wrong. I'm using Mobiola on Windows Vista Ultimate 32 bit and it works great. Apparently you were trying old 1.0 version. I'm using 2.2 version and it works fine. In this version they have updated the driver.
