How to set Wap through GRPS?
5 replies · 2,364 views · Started 13 January 2003
When I enter Services and Settings, can't seem to be able to select my GPRS in Default access point, the setting isnt listed. I'm not using a real GPRS account, I connect it through bluetooth. I want to use Wap through the bluetooth and my DSL connection. But the GPRS isnt listed under Default access point.
Or maybe the real question is, is it possible to use Wap through the bluetooth method mentioned in the forum ? I am able to connect through bluetooth and use webviewer, etc, but I'm asking if it's possible to use Wap using that method. If so, what do I need to do for the settings ?
Don't know if this is relevant but i've noticed that unless the gprs point you define has a gateway defined it doesn't seem to appear in the services->settings menu.
[quote="filicomp"]very proud of you.[/quote]
STOP that useless posting now! :evil: :evil:
Or go to waffle and post there, but try to have something to say, and not
just random sentences! :evil: :evil: :evil: :evil:
On my 7650 wap access is somehow strange too. I have in my phone few access points (Internet GPRS, Wap GPRS, Bluetooth, MMS), but if I want to choose default access point for wap, then I can choose just from Wap GPRS and MMS. I can't see other 2 access points there. If I wanted to create new AP for wap, then I was forced to use copy of Wap GPRS, make and make changes to it. If I made whole new AP, then I was unable to use it as wap access point. Does anyone know where is problem?
