hello I just got my n95 - it was a gift and was given in gold/sand-
Anyway I dont like the color.
I noticed on ebay that some companies sell the plum caseing for $30 USD.
Does it fit and how hard is it to change? do I need special tools or manual?
Can anyone recommend a place to buy one?
Also- it didnt come with a screen protector- where can I get one that fits w/o trimming and which is the best and any instructions on installation.
last but not least what size card can the N95 hold up to ?
I have a 1 gig and seems too small.
Thanks for your help in advance
hilz wrote:hello I just got my n95 - it was a gift and was given in gold/sand-
Anyway I dont like the color.I noticed on ebay that some companies sell the plum caseing for $30 USD.
You can buy good quality ' N95 Screen protector ' on eBay inc. P&P for about �3.
It is vital that you clean the screen with a cotton bud soaked in medical alcohol (then let the alcohol evaporate off for 30 seconds) before you attempt to fit the screen protector.
When it comes to fitting, peel off the rear protection film. Flex the screen protector so it is curved, then line up & apply carefully to the bottom of the N95 screen. Slowly lower the screen protector onto the rest of the screen, whilst constantly making horizontal passes with a cotton bud across the top of the protector to push it gently onto the glass and to press out any air bubbles.
If you go to Blueunplugged.com you will find alsorts of nokia N95 parts. As for changing them, i hear not too difficult as they are stuck/clipped on. There is a video on youtube of a guy taking one to peices and a thread with step by step pics on a slider issue but cant remember where.
As for the card, there is a new sandisk 4gb card that is compatible.
