Nokia n80 problem:mad:
7 replies · 1,789 views · Started 30 June 2007
hi!...does anyone know how i can stop the stupid installing on the phone...i get that installing thing..all the time when i turn back on or restart my mobile!.... is there any way to stop it?....thx in return....😉:icon4:
Installing thing? Never heard of that. Have you installed any software on it lately? Sounds like you installed or downloaded something that is causing it. If your not sure then you might have to do a full reset on the phone, otherwise if you know then you could just uninstall the program causing the problem via the app manager.
l did try the reset and the install from app and i cannot install all sofware ...i get error or...certicate expired...... 😞...
For the certificate change the phone date and should work. All the other, identify them and install again or remove.
Do a backup of personal stuff, and format the phone with *#7370# and the mem card. Try again...
A better way is to go in to the app manager and write down all the names for the files that cannot be installed.
Then grab a card reader (or plug the nokia lead in to the phone and set the mode to "Mass Storage"😉 and use your computer to search for any instances of the file names you wrote down, then delete them.
This of course only works for applications that have been installed to your memory stick - I've never had this problem for anything installed directly to the phone memory though.
