Where do all the downloads end up?
4 replies · 2,179 views · Started 30 June 2007
Hiyya,
Rather trivial question but I've downloaded a few apps over the past few days onto my N80 (say, truphone) and find I have to keep on redownloading them everytime I want to reinstall. This is my first smartphone and obviously unlike windows you don't get an option to save/run, all I do is click on the link and it prompts an install process. Is there anywhere they're all downloaded to? Thanks
dimensionfx wrote:Hiyya,
When you install an application to the phone from its built in browser or via the 'downloads' thing, the phone runs through the install process, then purges the installation file. A more ideal way is to download the applications to your computer and install from there, you could also store the applications in the "Other" folder within the phone using a card reader or bluetooth, that way you can use the file browser to install them again at any time straight from the phone.
Perhaps a question in return is why do you need to keep re-installing?
Thanks for that, re reinstalling its related to my truphone problem:
allaboutsymbian.com/forum//forum/thread/59493/&page=2
So I keep reinstallin in the hope that a .set file will magically appear. :tongue:
No luck though. :frown:
That's the thing I've read that everywhere... I don't know if it's just me but inside My Account I only have a link to a .SISX under upgrading/reinstalling truphone on the main My Account page?
