Hi
I have a N73 and I am trying to sync with ISync on my IMAC OSX. I have the latest OSS which has B73 built in to ISync.
However when I sync i get the following:-
18:27:41 Connecting to Nokia N73
18:27:45 Device "Nokia N73" connected
18:27:45 Receiving changes from "Nokia N73".
18:27:45 "Nokia N73" finished receiving changes
18:27:45 "Nokia N73" Processing changes...
18:27:47 "Nokia N73" engine processing complete
18:27:47 Applying changes to "Nokia N73"
18:27:47 Error [Nokia N73] An unexpected error occured.
18:27:47 Error Device "Nokia N73" synchronization failed
If i put a change into the N73 it shows up in Ical or address book, however no info from the Imac goes to the N73...
It will only Sync with Bluetooth and not USB
Any Ideas
Hmm, ive had loads of problems setting up my N73 to my mac and ive gone through the process so many times. What i found is the best way to help you is to just say start again. Go into your bluetooth preferences and devices and remove your phone from the list. Then go to add device > mobile phone and select your phone. I use BluePhoneElite which helps me manage sms and voice calls and i could only set it up by adding the phone to the mac in built bluetooth memory first. The open isync, again i suggest you remove the phone by selecting your phone > device > remove device then again add it to the menu. hit sync and see what happens.
Richard
OK,
Thought that might be the problem. I have sucessfully sync with my new shiny macbook pro so the problem must be with my Imac.
I will uninstall all the phones etc and retry thanks.
Hi!
I can sync perfectly with iSync but I cannot open the contacts with a voice command. In the contacts options there is also no entry for listening to the contact's name.
Anyone having the same problem? Or a solution?!?
