WLAN encryption detected as WEP instead of WPA
0 replies · 3,826 views · Started 01 July 2007
Hi there,
I'm having a very weird problem concerning the Wifi connectivity.
At first, I connected my N80IE to my wireless network without any problems. Chose WPA with a preshared key and everything.
Only now, every time I try to connect after this initial connection, the phone outputs something like 'WLAN-network not found', even though I'm very sure I've got the name and settings correct.
When I go and have a look at the 'available networks' screen, it shows my wifi network as using WEP encryption, although it used to say WPA before my first connection.
If I make a change to my wifi settings, like switch to a hidden SSID, again the first connection works, but afterwards it fails.
It's almost like the phone is storing the information incorrectly in memory, and needs to regain that data when that network has changed.
I've got the last version of the firmware (both phone and AP), and I'm using a US Robotics 8054 wifi router.
Anybody got some tips for me?
TIA
