Seems I can only view the most recent 30 SMS messages on my new E90. I have set the options to the maximum storage of 999 messages and am using the 512 storage card. Any advice how to change the settings so I can view all of my SMS messages ? thanks
E90 Viewing SMS Messages
I don't have a problem as you mentioned. The '999' you set is only for SENT messages. There should not be any limit for other folder.
I think you should try to set it to use memory card to store your messages... 30 SMS looks like a SIM card SMSes
In my symbian s60 phones I had no issues whatsoever. Had above 500 texts in the inbox and a lot of heavier messages on my card
