hi, my nokia 7650 has broken, after i installed the extended filemanager software, and then i shut down my phone, and i turn it on again, but it can't start and a message appear "App. closed startup WSERV 7"
please help me
my nokia 7650 is broken, please helllllppppp
Check this. http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=6013&highlight=
I hope this helps.
After boot, uninstall the software.
sorry to hear about that brah! u can try a hard reset. the code is *#7370#. you will lose all your current data and settings, so before you do this make sure you back up your files and plug your phone's charger. if you run out of battery during the process, it will make your phone unusable. hope this helps. 😊
