Okay so my home network has three security features, firstly it has WPA+WPA2 encryption, then it has wireless mac filtering, and above all, the network is not broadcasting (hidden)
i have the settings exactly correct in my phone and it works fine when i select the default access point as the home access point in both web and services. but how do i use it with truphone? when i go to internet tel, it does say connect with hidden WLAN but i have to enter the settings all over again and it just makes a new access point!
Also, when using other applications, they wont even show the access point.
I am on the latest firmware and also am using the same settings with my Nokia N95 which seems to work fine. Anybody got any suggestions on how to get around this problem?
I am not using Truphone 3.0 but the original settings.
