Any News of Support Software
7 replies · 3,391 views · Started 02 July 2007
Hi All,
Has anyone successfully installed or found the following.
1. Blackberry for the Nokia E90 (i went to businesssoftware.nokia but there was nothing there)
2. Bluetooth modem drivers. (you need to setup appropriate modem drivers on your PC)
3. A freeware filemanager that works with the extended screen to save unrecognised file attachments received via bluetooth.
4. A freeware/good shareware secure password storing utility/encryption software.
Thanks!
Did not try this personnally, but E90 runs on S60v3 so does E61 and E65. So go ahead and install the latest blackberry client for E61/E65. It should work.
Install PC suite, and once you pair the phone, it'll detect and install bluetooth modem
I used Y-Broser and so far works fine.
I tried the blackberry e61, e61i and e65. all doesn't work for the nokia e90... 😞
after running through the "installation" at the last stage, it says installation failed.
OngL wrote:1. Blackberry for the Nokia E90 (i went to businesssoftware.nokia but there was nothing there)
BBC 4.0 for the E90 is now available on Nokia's Business Software page but only for the European region. It still works though on Asian handsets.
Then i'll install the Y-Browser V 0.5 on my E90 i'll get the message that the zertifikate is not valid!?
What shall i do?
pitmac😊
thank you.
it works.... but its SLOWWWWWWW with active standby on. To the point its unbearable.
capkapak wrote:BBC 4.0 for the E90 is now available on Nokia's Business Software page but only for the European region. It still works though on Asian handsets.
