Anybody know how to modify/delete/change/add icons on the home screen? There are 6 by default .... I just installed WorldMate, and it removed one and added itself -- is there a way to modify this myself, so I can put my top 6 most used application on the top (above the WLAN scanning off and Calendar icon) ..
Thanks in advanced.
P.
praefectus wrote:Anybody know how to modify/delete/change/add icons on the home screen? There are 6 by default .... I just installed WorldMate, and it removed one and added itself -- is there a way to modify this myself, so I can put my top 6 most used application on the top (above the WLAN scanning off and Calendar icon) ..Thanks in advanced.
P.
Settings -> General -> Personalizations -> Standby mode -> Active Standby apps
Thanks Bro! Much appreciated!
dorisall wrote:Settings -> General -> Personalizations -> Standby mode -> Active Standby apps
