When its on the reboot screen, it just hanged.. I need to remove the battery and switched it on again. Does anyone knows what is the problem?
Cannot use Fexplorer to reboot on N70!!
Check if you have the last firmware version inside. If is the case, just format the phone.
shauntan wrote:When its on the reboot screen, it just hanged.. I need to remove the battery and switched it on again. Does anyone knows what is the problem?
Ignore nj7, he's always answering with "check firmware version/format the phone" for whatever problem you can have. It doesn't work to restart N70 with 3rd paty software. It will always hang and you can't do anything to solve this. I'm afraid that you can only power off/on manualy.
yeah! n70 or any n series atleast what i have handled, wont reboot by any 3rd party softwares. I fear they wotn support such feature, but only option is to simply switch off n on.
my n70 will reboot fine with fe. have here 3.0546.2.3 18-11-05
Wirelessly posted (Opera/8.01 (J2ME/MIDP; Opera Mini/3.1.7196/1690; en; U; ssr))
People don't seem to know what they're talking about here!Reboot on fexplorer 1.15 to v1.17 works fine on the n70.Other apps which reboot fine on the n70 are keyman and smartsettings.I have all apps on my n70 so i know.
damo666 wrote:Wirelessly posted (Opera/8.01 (J2ME/MIDP; Opera Mini/3.1.7196/1690; en; U; ssr))People don't seem to know what they're talking about here!Reboot on fexplorer 1.15 to v1.17 works fine on the n70.Other apps which reboot fine on the n70 are keyman and smartsettings.I have all apps on my n70 so i know.
My N70 was not rebooting; tried with several apps on two different firmware versions so don't tell me what it didn't work on MY N70.
ratza wrote:damo666 wrote:Wirelessly posted (Opera/8.01 (J2ME/MIDP; Opera Mini/3.1.7196/1690; en; U; ssr))People don't seem to know what they're talking about here!Reboot on fexplorer 1.15 to v1.17 works fine on the n70.Other apps which reboot fine on the n70 are keyman and smartsettings.I have all apps on my n70 so i know.
Well ratza as already instructed(even by the poster above me)i have no problems with reboot.Another 2 apps on my phone are capable of reboot and also function as required, and these are appman and xplore.On a different note my fw version is 5.0616 ..Think it's hightime some of you performed firmware revisions don't you ratza?
U guys r talking about n70...mine is N70ME....but it wont reboot..simply hangs....may be a firmware upgrade mit do the job...lets see
damo666 wrote:Wirelessly posted (Opera/8.01 (J2ME/MIDP; Opera Mini/3.1.7196/1690; en; U; ssr))Well ratza as already instructed(even by the poster above me)i have no problems with reboot.Another 2 apps on my phone are capable of reboot and also function as required, and these are appman and xplore.On a different note my fw version is 5.0616 ..Think it's hightime some of you performed firmware revisions don't you ratza?
Well my firmware was 5.0638 before selling the phone. Since you're such a smartass, why don't you keep on rebooting your phone just to prove me it works?
@joncenawordlife - I was talking about a generic N70.
@ratzbrain..I'll provide a step by step tuition on how to perform a re-start on your phone.1st of all launch that little programme called fexplorer, appman, xplore(lcg), keyman or that not so small smartsettings and look for the option that says restart device, reboot, etc..Scroll down, or up if needs must..Click on..Then when prompted with a query like thus=RESTART DEVICE-YES or NO..Click yes..Voila..The phone restarts and you're ram is all refreshed.Best of luck numpty.
damo666 wrote:Wirelessly posted (Opera/8.01 (J2ME/MIDP; Opera Mini/3.1.7196/1690; en; U; ssr))@ratzbrain..I'll provide a step by step tuition on how to perform a re-start on your phone.1st of all launch that little programme called fexplorer, appman, xplore(lcg), keyman or that not so small smartsettings and look for the option that says restart device, reboot, etc..Scroll down, or up if needs must..Click on..Then when prompted with a query like thus=RESTART DEVICE-YES or NO..Click yes..Voila..The phone restarts and you're ram is all refreshed.Best of luck numpty.
Man, you're such an idiot... a spoiled child which has nothing better to do. How can you be so stupid that you don't understand that the phone froze in the moment of trying to restart? I don't have the N70 anymore and all the SW I've tried cannot restart the phone. It simply frozed and it needed to take the battery out.
