phone switch itself off (solution)
1 replies · 1,684 views · Started 02 July 2007
if you like me have this problem, i found out (after the 3rd replacement) it is because the newly designed crap battery has got "play" and looses contact with the phone when ie is shaken sideway or from a fall (dropped times and times again before the n80 - never went off)
my solution ideally would be to return it but cannot live forever waiting for the dhl man, so i just put a bit of paper folded on the right side (if you are facing the back of the phone ) in order to avoid the play.
since this morning it never went off again.
i should copy this message to nokia support....
