Syncing custom fields with Outlook
2 replies · 2,955 views · Started 03 July 2007
Hey guys,
Just spent a couple of hours googling for the answer to this with no luck, so thought I'd ask around here.
I just got my N95 set up to sync properly with outlook, but I've noticed that none of my custom fields (or labels as they're called on the phone) for contacts are synced from the phone across to Outlook.
Does anyone know how to get this working properly?
Thanks.
- Aaron
but I do have the same problem and I can't believe that there's no solution out there - I've been googling for ours too...
I think that this can be solved with a Visual Basic Script in Outlook but I'm no expert - perhaps someone out there is?
Unfurtunaitly this is not simple and it's not Outlook related. The data is read from phone by the PC Suite software, and that software shall map the custom fields to the Outlook fileds when syncing.
