Help-me please deleting a folder... e62 !!
5 replies · 2,588 views · Started 03 July 2007
Hello everyone 😉
i bought recently a e62.
After that, i created some folders to help-me to organise my apps...
now i need to delete one of this folders that ive created... and i got this message "Unable to delete 'Folder'"
1- The folder is empty
2- Every folder that i create, i cant delete...
3- i searched a lot but find no solution
Please, can anyone help-me??
Thanks in advance!!
Try to delete them with a third party file explorer, e.g. Y-Browser. Normaly you can't delete something when the file/folder is in use by another application. Make a reboot and try again.
but i cant find this folder using y-explorer or xplorer...
folders ive created, are located in main menu application...
some tip???
sysforce wrote:Hello everyone 😉
Thanks in advance!!
Now that's wierd!! You've tried rebooting the device and trying again?
Steve
The same thing happens to me, I also have the E62 and it's impossible to delete folders you create in the Main Menu. Very annoying, if anyone finds a way to delete them or locate them on the Y-Browser we would appreciate it!
Best,
Pedro
