Help with Tracker Syntax
0 replies · 1,988 views · Started 03 July 2007
To help curb my growning iPhone envy, I knocked up a skin for Tracker 4 to use on my P900. There are a couple of things that would make it 100% - but the searching i've done tells me they aren't possible - but I figured i'd check with the guys on here before I gave up.
1. Is it possible to display the current signal quality
2. Is it possible to display the current battery life
3. Can you make Tracker change pages and lock/unlock with 1 button press?
Cheers for any help....
