I've no idea what I'm doing wrong. Seemingly the games transfer across to the E61i without problems, and the website I downloaded them from says they are designed for Symbian on the N61i. The file extensions are .sis if that helps. When I try to install it says "installation not supported".
Might it be that Vodafone have locked down this function??
Any other ideas? Anyone got links to some sites with free games that will definitely work on my E61i?
(Sorry if this is a total n00b post, I have checked the FAQ and other threads already).
Check that your phone is set to allow the installation of all programs not just verified ones. Got to Tools - App. Manager - Options - Settings - And check that Software Installation is set to "ALL" not "Signed Only" and Online Cert Check is OFF
I tried both those fixes before I made my first post. No joy!
runtheroad wrote:I tried both those fixes before I made my first post. No joy!
I suspect the web site you're grabbing them from is lying about compatibility. All free games for the Nokia E61i and other S60 3rd Edition devices are listed at my http://3lib.ukonline.co.uk/nonagss603.htm if that helps.
