messages so easy deleted/lost while typing
3 replies · 3,335 views · Started 03 July 2007
when you type a message and accidentely hit the "end-key" instead of the "clear-key" (they are quite close) then the whole message is gone instantely?
This is extremely annoying. On my old 5140 when I did such thing or when I had to stop typing on a sudden to make or answer some call then next time, when I started a new message, the old interrupted message was here again.
no such thing on 5500? any idea how to change this behavior?
It just drove me mad, when I lost a handcrafted 500-char-relationsaving-message in the blink of an eye 😉
thnx
The interrupted message should remain in "Drafts".
I also remember seeing an app called "NoRedKey" somewhere...
gruad23 wrote:when you type a message and accidentely hit the "end-key" instead of the "clear-key" (they are quite close) then the whole message is gone instantely?
thnx
it is not gone, recorded in the drafts folder (in messages menu)... I thought just like you when I first see the thing...
