hi does anybody knows if there is a pc suite for the nokia 3650? when it comes out? 😃
pc suite for 3650?
Yes, there will be. But the 7650 PC suite works too. I have tried it. 😃
does it run on Win 98SE?
Yeah, I have it on 98SE and XP. Both work fine.
XP was a bit tricky though.
as long as it works on 98SE that's fine - saves me upgrading! i don't think the SE P800 pc suite runs on 98SE.
[quote="JyriK"]Yeah, I have it on 98SE and XP. Both work fine.
XP was a bit tricky though.[/quote]
what was though about it then because ive got xp to
ps thanx for answering 😃
you get an extra file transfer plugin with 3650 pc suite too 😊
you get an extra file transfer plugin with 3650 pc suite too 😊So, could you please provide a link where to download it? 😉
[*] note to admins, I don't think I asked for "warez", and btw I will anyway get a 3650 early, so I *will* be entitled to download it 😃
True, but only if its on nokia site, like it should be.
No direct links though, please. Link to site, if possible.
I dont think that a plugin for PC Suite is warez. PC Suite is freely available to everybody form Nokia anyways! So dont worry!
Do you think it could work with the 7650?
[quote="GhostDog"]Do you think it could work with the 7650?[/quote]
😃 YES! I have seen in others forum where people using 7650 PC suite for 3650.
[quote="Anonymous"][quote="GhostDog"]Do you think it could work with the 7650?[/quote]
😃 YES! I have seen in others forum where people using 7650 PC suite for 3650.[/quote]
You are saying that you have seen people use PC suite that was developed for the 3650 with the 7650,right?
What does the file transfer plugin do? Remote Browsing?
PS: Why dont you register,so all of us know who are we talking to 😃
Its free 😃
[quote="JyriK"]Yes, there will be. But the 7650 PC suite works too. I have tried it. 😃[/quote]
I tried also this but I could not download the videos. How can I download my videos? Anybody knows?
[quote="judell74"][quote="JyriK"]Yes, there will be. But the 7650 PC suite works too. I have tried it. 😃[/quote]
I tried also this but I could not download the videos. How can I download my videos? Anybody knows?[/quote]
http://allaboutsymbian.com/phpBB2/viewtopic.php?t=7066
Hey Thanks!!! 😃
