Can't re-install Calcium - "Certificate Expired"
5 replies · 6,459 views · Started 04 July 2007
I had this working fine for a while but following a re-flash I can't get it to install: keeps telling me "Certificate Expired". Yes, I have Software Installation set to "all" and Online Certificate Check "off".
Set the phone date back a couple of years, install the app (what is Calcium anyway?) then return the date to todays. That should work...
millski wrote:Set the phone date back a couple of years, install the app (what is Calcium anyway?) then return the date to todays. That should work...
Yeah, this has happened for me on a few apps. It only checks the date on installing so play with the date to get one it accepts then change it back once installed.
Oh and calcium is a free calculator app which is much better than the built-in one becasue it uses the direction buttons for the operations. On their site they give the example that doing 2/3 x 7 takes 13 clicks on the Nokia calculator but only 6 on calcium!
Its available here: http://www.allaboutsymbian.com/software/item/Calcium_for_S60_3rd_Edition.php
Thanks for the tip. I'll try that too. Can't live without Calcium.... I tried to send a e-mail to that support address on the software page on the AAS software description but it bounced back. Gess the developer isn't updating it anymore....
