Hi all,
I cant seem to find a definitive answer about the size of the Torx screws that hold the facia in place (the bit housing the LCD) on the N95.
Does anyone know for sure what size they are? I suspect "T6" but I have read conflicting opinions...
Hi all,
T6 fits better, i just changed mine to BLACK!!! 😃
Ronaldo-9 wrote:T6 fits better, i just changed mine to BLACK!!! 😃
ah cool - where did you get the black facia? from ebay? I was going to try and get a black one.
When you say T6 fits better you mean the screwdriver size fits better or T6 screws fit in the holes better (if you see what I mean!)?
errmm if were to replace the facia you would use the same screws anyway. screwdriver fits better on the screws
Ronaldo-9 wrote:errmm if were to replace the facia you would use the same screws anyway. screwdriver fits better on the screws
argh well I just got a T6 screwdriver and it seems too big! *sigh*
