I have a problem whit those programs:
1. I have set that Extended Profiles will change profile selected time.
2. My Screen Saver goes in sleep mode.
3. When the time is selected time, Extended Profiles won't change the profile! (=it does nothing and it should DO)
If I set Screen Saver's sleep mode to the "never" or not Screen Saver at all in phone then the Extended Profiles works fine.
How I can use SleepMode in Screen Saver? (because it eat less the battery, I think)
Thanks!
[quote="Urpo"]Hi,
Thanks![/quote]
hi, sorry cant help you with other problems, but if you want to save some battery while using the sSaver, put the sleep mode after 1 hour. that's what i do.
hope this helps. 😃
[quote="Urpo"]Hi,
Thanks![/quote]
Me too, plus the keylock function of Extended profiles pro stops working.......Good Luck
