Hi all
Anyone got this combination working? Installing from TomTom Home doesn't work even though Nokia PC Suite is happily synching with e61i. Mobipocket installed no probs and works fine.
Memory is 2gb microSD card.
Tried to install s60 series 3 version from DVD to SD memory card in reader but wouldn't let me do that - said not compatible with my phone. The only version it would let me install to the card was the UIQ3???
Extracted .cab files from DVD and then copied them to SD card. Running .sis file from Nokia PC Suite Install Apps seems to start OK but then phone aborts install with 'Cannot install app' error.
TomTom support not responding.:frown: :frown:
Anyone any clues?
Thanks.
Just been on the phone to TomTom.
Response is that TomTom Navigator version 6 is NOT compatible with the Nokia e61i. Works fine on e61. When asked if they had any plans to fix problem replky was non-commital. I pointed out that the e61 was end of life wef end July 07 so they would need to fix it but again no commitment.
GGGGGGRRRRRRRRR.................................
And I thought it was only Microshaft who broke things with upgrades!
works fine on mine?
have you set your security settings so you can install 3rd party apps?
Biggest problem with tomtom on the E51i is that you cannot type a 'j' as it appears as a ' instead.
cyrusir wrote:works fine on mine?have you set your security settings so you can install 3rd party apps?
