sDoubler 1.20F problems
3 replies · 2,301 views · Started 13 January 2003
I have three problems with the new version, which I like more than Stacker anyway 😊
1. I wanted to disable special support for RealOne, but the setting to Off cannot be saved. Every time I open sDoubler, the "Special support for" is On again.
On the other hand, I don't understand the usage of this settings. Who need this time consuming pack/unpack of RealOne, everytime one open/close Services app?
2. When I open the Service app, the RealOne is unpacked, but when I close the Service app, the RealOne remain unpacked and sDoubler report Ratio: 100% and the Menu option is Unpack.
3. When I delete a group from Files tab, the focus is lost, and I have to switch back to Application tab and then Files tab to get focus again.
Hello Eidrian,
Thank you for report!
Version 1.21F is available to download from our website, without reported problems.
Regarding your question: RealOne may be invoked directly from WAP browser (with streaming video), this feature (auto decompresing with Wap browser) was requested by some user's...
Anyway, by default these feature is now disabled by default.
BR,
Robert
PsiNT
Thanks for the update, it is working now.
Seems that you are a perfect example of Extreme Programming. 😊
Could Sdoubler do something about the progress bar, although its nice to have it running at the bottom of the screen, but its hard to determine the actual progress when its its running round and round.
