Nokia MapLoader 1.1 g
3 replies · 4,486 views · Started 05 July 2007
I downloaded the newest version of MapLoader (Nokia_Map_Loader_1_1g_Setup.exe) and I can't install it. I am getting the communicate "Program to big to fit in memory" under Windows XP. Did anybody encounter this problem?
Thanks in advance,
Slawek
I downloaded Nokia_Map_Loader_1_1g_Setup.exe from www.smart2go.
Undstalled my current Nokia Map Loader and installed the new one.
The installation was running smoothly without any probem. Even the program is starting normally and I can download the maps.
Regards
Geraner
I downloaded the program again from the address you suggested.
... and works correctly!!! Thanks a lot 😊 .
