what headphones should i get
5 replies · 2,021 views · Started 05 July 2007
Hi all.
I should get my N95 tomorrow if the postman does not nic it.
i fancy a bluetooth headset but dont know what to but.
What do you all recon i should get.
Thanks#
Gary
I am also interested in buying a bluetooth headset.
Can anybody recommend any?
Can I listen to music successfully with the headset on only one ear
(with no cables at all) or do I have to buy a stereo one (with a seperate bluetooth receiver connected via cable to earphones)?
I have iTech BlueBAND stereo headphones and the are very good. Clear and easy to use. They are an all in one unit (no cables) so you just pair them to the phone and thats it!
I just bought the Nokia BH-501 (black) headset and overall the quality is good but the styling is an acquired taste and there's the occasional cut out, in both music and calls when using it. Not too sure whether the cut out problem is due to N95 running other applications or due to the headset itself though.
