Mobile Navigation Software
6 replies · 2,177 views · Started 06 July 2007
Has anyone managed to get any type of speed camera notification with Route66 or any other Navigation package running on their n95
The GPS is ace and so much easier than having to keep digging out the dash mount...but the fact the speed cameras are not on does knock it back a little.
Cheers in advance
Navicore (www.navicoretech.com) works well on the N95, but not (yet) with the internal GPS receiver. It has speed camera information, user-defined POIs and a free traffic information service.
(Not connected with the company, just a happy customer.)
Co-Pilot works with the internal GPS receiver, and has AFAIK, some speed camera info? May be wrong, but could be worth looking into....
I'm hopefully getting an N95 in a week or so, was going to get Co-Pilot as well due to the compatibility thing.
Yes, Copilot is the best GPS software for the N95. It does indeed support custom user installable POI, i.e.camera locations.
BTW, I have lost count of how many time thats been posted on these forums. These are the worst forum i have ever been on for people asking the same quaestions over and over and over without searching first. FFS people, use the seach function!
autopilot wrote:Yes, Copilot is the best GPS software for the N95. It does indeed support custom user installable POI, i.e.camera locations.
Yes, you do have a valid point re the same questions being asked, esp this one re Co-Pilot, but then again, the search function can take ages to trawl through all the responses, can be a bit of a nightmare!
It doesn't take much though, just to reply with a couple of lines guiding people in the right direction.
cheers.
nottmbantam wrote:Yes, you do have a valid point re the same questions being asked, esp this one re Co-Pilot, but then again, the search function can take ages to trawl through all the responses, can be a bit of a nightmare!
cheers.
People should not be lazy then, it's hardly a nightmare.
If you want to write a couple of lines fair enough, but the person asking the question is not going a get as good as response as previous people did because people are sick of hearing the same thing and dont want to answer it again. So it's actually more beneficial to search, than to get a muted response. Furthermore, it just bogs down the forums and new thread more quickly.
