Heeeelp! n80 gallery finding finding wrong images
4 replies · 2,326 views · Started 06 July 2007
hey everyone,
i'll get straight to the point, i recently installed a cracked version of tomtom 6 on my n80. All works fine except when i open the gallery it finds all the images that are in the tomtom folders (not the maps) but things like small speed signs etc. This is very annoying as there are quite alot, so i wondered i anyone knew how to get rid of them but not from tomtom
thanks in advance
adam
Uninstall your pirated version of tom-tom, go out and buy the original, install that instead, then you wont need to come back and ask this question.
dchky wrote:Uninstall your pirated version of tom-tom, go out and buy the original, install that instead, then you wont need to come back and ask this question.
Another usefull answer.. just like this one.😡
It is there if you search mate...😊
chears everyone,
i'll continue to look, but not not found anything yet.
adam
p.s a special thankyou to the holyer than thou, angel dchky
