today the 9300 went flat so charged it and it asked for the security code (which i have used before 12345 but this did not work, had another try but with no sucess. tryed to obtain master unlock code with the imei number this generated a 10 digit code but again the phone states this is the incorrect code..PLEASE HELP !!!!
9300 security problems
Where did you get the master reset code from? If you got it from any code generators, It might have been given wrong code. You can get the accurate master reset code for your Nokia 9300 from www.unlocking4free.com/nokia-master-reset-tool for free by submitting your IMEI number.
I think you should update your software which will vanish up every codes in your phones.
thank you
My Curve 9300 keeps rebooting all time (OS 6.0 Package 2391 v6.0.0.534)
I just leave the device unused for some minutes and then it restarts automatically (black screen with white status reboot line). That might happen upto 30 times a day. The device is brand new, battery is changed to a new one. Afterwards i can work with the BB fine for as long as I wish. Any help is highly appreciated. Thank you.
https://www.rx247.net/viagra.html
may be bcoz of viruses, your device is facing this problem. Get it scanned and see.
Thank you, I think if mobile phone phosphite shell very good feel very good, give a person a kind of poetic feeling not to be stained with fingerprint design, is not easy to dirty dust, yi qingjie can effectively shock and buffer bump down explosion protection function
I think you should go to the service centre as the company offers a warranty of 18 months.
Very grateful to you all news, LG mobile phone fashion design, precision process quality, satisfying the screen and the bell is other brand mobile phone does not have, I like his shell design is very distinctive, feel very good
SDK wrote:There are a lot of users often when in charge to leave her cell phone, in fact this will be very easy to hurt mobile life, because in charging process, cell phone circuit board will fever, at this time if there is foreign phone, may produce instant return current, the mobile phone internal damage parts
yes, but the internal damage will be negligible.
Thank you, I think SONY mobile phone shell pretty good is not easy deformation, avoid the loss of characteristics to let you enjoy can better prevent fingerprint and the effect of the dust
SDK wrote:Thank you, I think SONY mobile phone shell pretty good is not easy deformation, avoid the loss of characteristics to let you enjoy can better prevent fingerprint and the effect of the dust
Not only sony, Nokia is also the same.
