Hi folks, did a quick search and found lots of AVI -> MP4 but not the reverse. Anyone know of such a piece of software?
Many thanks,
Rikki
Many thanks,
Rikki
G o o g l e is our friend 😉
monica _69 wrote:G o o g l e is our friend 😉
Indeed it is but rather than wade through the valleys of unknown spyware, trials that dont work and shoddy software I thought I'd ask the learned minds of this forum for their insight rather than throw caution to the wind and install 7 new applications on my system in the belief that a suitable solution would be found. 😉
Rikki wrote:Indeed it is but rather than wade through the valleys of unknown spyware, trials that dont work and shoddy software I thought I'd ask the learned minds of this forum for their insight rather than throw caution to the wind and install 7 new applications on my system in the belief that a suitable solution would be found. 😉
Quicktime Pro does this well but I think its £20
QuickTime Pro or ImTOO 😊
Download a piece of software called super. It converts formats into whatever format you can think of and best of all its free 😊
