Pc Suit Contacts
1 replies · 1,624 views · Started 13 January 2003
hi there all ..well another problem lets see if anyone can help .. i had 9110i earlier the pc suite was very easy i mean u can add ur contacts and then upload in the phone .. why cant i see such a thing in 9210 pc suite ? did they forgot to put it in or am i looking at the wrong place .. i have installed the upgarde software .. but it dosent work either i mean my phone is connected to the pc suit but when i try to upload the contacts save in a text file it says the phone is not conencted ... WHY !!!
I was confused also when I turned from 9110 to 9210.
You will have to live with it. I used to sync (I still do) using Outlook. It is a more convenient way. I am shure AllAboutSymbian will help you find answers to all your further questions.
In the mean time, try to take a look at http://www.allaboutsymbian.com/newsdisplay2.php?id=6424
and follow also the links to the product as well.
Good Luck and enjoy AAS.
Bilal, registering is free, and you will have access to atachments as well.
