N72 Screen
1 replies · 1,203 views · Started 07 July 2007
Hi..i have a Nokia N72-5...the problem is with the screen light timeout..dont know how to describe it...i have it set to 5 seconds and power saver time out to 1 minute..basically the lowest it can possibly go..but that doesnt work it takes well over 5 seconds..maybe 15 or more for the light timeout to come into effect...is there a way to fix this??btw..i have done soft resets n hard resets n it hasnt changed this(didnt do the resets so i can fix the settings tho..was to format fone)
There�s the way that thing works... You can only use always last firmware, and maybe have some improvements (or not).
